vincent
Was concerned about the pressure drop at the gauge when using either my greenhorn (jetted at 02 straight across) and the 360i.
this video shows just using the 360i. I have 125 of of solution hose out. I set the psi at 400 to get a good starting point.
As you notice, it drops 200 psi when the trigger is pulled, but it also maintains that dropped pressure. I did the same with the greenhorn and the same thing happened.
After this video was taken, I talked with Les, and made sure the belt was tight on the waterpump. And I also took the filter off inside of the waterbox.
Any other thoughts or has anyone experienced this.
6]http://www.youtube.com/watch?v=eQ6zELjmNB06]
