Louis
So if every hour is 35 to 37 miles on your van do you claim this on your taxes as mileage?
Thank You
Thank You
Newman said:Illinois also has a fuel tax refund, check with your state.
You may not claim the machine hours as equivalent mileage deduction. You can get the Federal Tax you paid for gasoline, per gallon, refunded because a percentage of the fuel consumed was not putting wear and tear on the fine streets you were driving on.
The first time I did it by the book, as my fired accountant told me to, wasted a lot of time, and the final number was as stated by Mr. Boyle, 1.46 gallons per machine hour for a White Magic Pro 1200
Dumbass way I did it by the book:
1) Go through every friggin gas receipt (I had 100 of them) and record the gallons of fuel purchased at each fillup, come up with number of gallons purchased for the year
2) Record miles driven by the truck for the year
3) Estimate on road MPG for your loaded truck (12 mpg Chevy 1 ton extended)
4) Subtract gallons used driving from gallons purchased
5) Enter machine gallons consumed on form 4136
X2 don't spend too much time on it. Even for us with dozens of units it is only about 3-4k a year I think.Fred Boyle said:Don't complicate this
Take your machine hours for the year (should have a maintenance log anyways). Determine how much fuel your TM uses per hour and you have you gallon usage
It's only a couple hundred dollars in taxes per TM .
