M
maker
I have been testing out some urine treatments with some cat urine soaked carpet that was pulled from a rental.
Cut it into 8" squares and soaked pieces in half a gallon of Quatalot and Odorcide just a little stronger than suggested.
Let each soak 20 minutes then rinsed front and back.
After words they both smelled like the treatment that was used.
Then I put them into gallon sized zip lock bags and put them into my van.
2 weeks later the odorcide carpet smells as much like odorcide as it does cat urine.
The quatalot only smells quatalot.
Thought some may be interested.
I actually expected the results to be the exact opposite. Maybe because the Quatalot cost so much less per use than the Odorcide (something like 10 times less)
