KevinD said:I use mine all the time in my apartment buildings.
Although there is a slight danger of collapsing a weak pipe.
Once I watched a plumber try snaking a customers bath drain for over 2 hours with no luck.
I put my hose over the drain and all of a sudden it pulled up what looked like a 3' ponytail that had built up in the drain from her waist length hair.
I'm sure he was in the house cleaning , but still funnyConnor said:KevinD said:I use mine all the time in my apartment buildings.
Sounds like he was a moron. You had two hours to kill watching a moron work?
jcooper said:"3' ponytail that had built up in the drain from her waist length hair."
I'd throw up!
Jay_wat said:nasty,slimey,,smelly,,,i dont miss doing those calls,,,, Lol but nothing is worse for smell then a grease trap!!
Connor said:Sounds like he was a moron. You had two hours to kill watching a moron work?
Connor said:It was already worn out, you just exposed it.
Kinda like when you see an old galvanized drain that's not leaking and you run your hand under the bottom of it and it just falls apart, sometimes the only thing keeping it from leaking is the muck in the drain line.
There are plenty of old cast iron drain lines that start leaking after cable is run down them and it's not because the cable is too aggressive, the pipe is just paper thin.
Ross Buettner said:Like the old lead and oakum packed hub joints? That shit broke just looking at it.
