Jeff Brown
Wondering what would be the down side of use two dual vac Air Hog Plus side by side in a van using a Y to split one hose going to both units for greater lift and cfm? And maybe using higher flow with customer water pressure and propane heat.
Or adding a external pump and a propane heater.
Or maybe using a M5 and an Air Hog Plus or Flood Hog Plus since they both have the same vac set up and the M5 already has a pump wouldn't need the external pump.
What would be your thoughts on this?
Thanks
Thanks
