Question on changing blower oil.....
Blue Monarch
Dirk Wingrove
Getting ready to change blower oil(Roots 45). There are fill and drain ports on both sides. Is it a shared reservoir, or do I need to drain and fill both sides?
Look for my article on here for changing blower and cat pump oils ...coming in for landing and gonna loose wifi on plane soon
KevinD
Kevin Dumas
Is it a dual splash? (oil on both ends) No the reservoirs are not shared.
But if you have oil on the back end with 2 drain plugs (and grease zerks on the drive end) it is. (you will only need access to one plug)
dgardner
Dan Gardner
There are oil drain hoses available - makes future oil changes easier....
http://www.northerntool.com/shop/tools/product_200311689_200311689
Blue Monarch
Dirk Wingrove
Gardner....YOU ARE THE MAN! I just logged on to ask the question as to where I get those. What a pain without them.
Reactions: dgardner
Keith
Get a 90 degree elbow also (though I don't know your set up) you will probably need it.. I should have done it long ago(still haven't)!!:icon_redface:
Reactions: dgardner
You will want to use a simple ball valve before installing that drain hose, or you will be wasting very high dollar ISO 220 oil filling that drain hose for no reason.
At 40 dollars a quart I don't want 1/2 pint of oil just filling a drain hose.
Mike Draper
you can go to any hydraulics store and have a hose made meg. I have them made for all my oil ports.
Senior Chavez tu eres un whey!!!
If you do it like the picture above you will have nothing to worry about.
I called my mother to ask her what you said. She said she wants to talk to you, so I gave her your number. :eekk:
That was NOT nice! :(
fooker!
:lol:
