Check valves simply stop the down-tube or wand sol hose from slowly emptying through the jets after you release the valve. They won't do anything to stop a leaking valve.
Here's a tip: Do not hesitate one moment to fix a leaking valve. A leaking valve means the seals have eroded or failed. Once this happens, continuing to use the valve runs the risk of proceeding from a metal-to-"rubber" contact within the valve, to a metal-to-metal contact between the valve body and the actuating stem. Once the metal contacts the metal, you get a real friction erosion that effectively ruins the valve body. Once this occurs, subsequent kits will only last a scant short time, as the eroded metal literally grates on the new rubber seals. Hence seal failure begets seal failure, and the user wonders why his seals don't last. The only remedy then is to replace the whole valve, and learn from the experience. Always have a spare kit at the ready, and replace it at the first sign of seal failure. Do this, and the kits will last much longer, and so will the valve.
