Quick Connects - Which one leads?
KevinD
Kevin Dumas
And if you blow that lead line, you can't throw another spare onto it. I worked for a company once that did it that way and after having to run out a new "lead pressure line" a few times, I switched it so that all lines were exactly the same and could be used interchangeably.
That is why it is a good idea to carry a tool box with some wrenches and some teflon tape.
A couple minutes to swap your ball valve and disconnect to another hose.
Reactions: Lee Stockwell
