dgargan said:
What is the difference between that machine and a Judson which requires a water box and pump for fresh water?
not sure anything in respects to a pump drawing from a "pooled" water source .
All pumps can draw from some distance
Maybe Brent should clarify what he's considering .
are you asking if you can by-pass the TM water box and pull directly from a fresh tank??
There are variables, but the short answer is "yes"
or...
are you asking if you can by-pass water box and hook up a garden hose direct to the pump?
Short answer there is "yes" too.....provided the incoming source has same or more GPM flow than outgoing flow
Most pressure washers run direct to the pump.
(which begs a question I'll ask DooDaddy in a minute)
It's "best" to have some kind of "pooled" water source on a TM.
be it a couple/three gal water box, or remote fresh tank to draw from .
bee-cozz..
While it may be rare you'll run into a water supply that can't keep up with tool flow, it's not unheard of...particularly in country where wells are the norm
With the on/off duty cycle of most tools, a water box or other pooled source allows a poor GPM flow source to keep up
Force- feeding the pump can result in blown internal seals
i don't have any pressure washers with near the hours the TM does
but i know some pro's that do
are they rebuilding their pumps more than we typically do?
Thanks
