- Joined
- Jan 15, 2008
- Messages
- 3,534
- Name
- David Sweeney
You'll have to teach me that trick.. I've never been able to to do that! :shock: The most important part is don't over lap your heat sets.
sweendogg said:If I'm doing repairs with the kool glide, I'll use their thermal stick glue with my glue gun to attach both pieces first and seal the edges, then I'll heat the seam.. I always feel safer doing it this way.
I've used hot iron and wet rags/irons for over 20 years, but I just talked with a friend that uses the kool glide and he said he was powerstretching away from a seam in less than 5 minutes, is that true guys? BTW I can't believe cookie cutters are still aroundsam miller said:I think this answers my question! does a kool glide seam set as strong and faster then a regular iron.
were You have to hold a seam for 5 min so you get no gapping on a reinstalled flood???
It would be nice to speed up that process.
I just watched a Youtube vid on that...that will take quite a bit of time...it looks effective for seams but time consuming and it doesnt look like it's cheapJohn Middleton said:A Seamer Down Now will allow you to stretch off ANY tape in a very short period. Their add says 20 seconds not 20 minutes!
I dont do installation, only repairs, but I find it invaluable when doing the likes of pattern mis match correction.
John
idreadnought said:I have several templates that I use. 4" 6" 8" and some rectangular ones. I could patch the carpet in those 4 places (if they fit my templates) in about 40 minutes or less. I use a Koolglide iron and would charge less than a hundred bucks for all of them. I paid big bucks for my templates, Ok, Ok, I got them all for about 10 bucks. I went to a metal fabricating and sales center and picked through their scrap pieces to find my templates made out of aluminum. Pencil money
