REPLACEMENT 3 STAGE VAC MOTOR
Picked up a very cheap portable and it has a tired 3 stage vac motor. What vac motor to buy somewhere that has a good price. 5.7 inch 3 stage
Mytee.com offers 2 such types vacuums. 2 different CFM rates and 2 different electrical power requirements.
They maybe cheaper from your local dealer instead of direct from Mytee.
Powr-flight is crap! Low prices but crap!!!--- the kind of stuff temf would promote. :dejection::stir:
If it is the only vacuum motor look for a 13.8 amp replacement. This will give enough amperage to run an aquatech 220 psi diaphram pump which will give you 160 psi on a 4 flow wand
want one of them new higher cfm low amp ones.
Actually it's on a old castex walkbehind extractor and has a 100 psi pump.
then go with the Mytee HP 3 stage vac.= model C302LA- 9amp, 100cfm, 130 lift.
other option is Mytee C302HP. = 14.5 amp, 113 cfm, 145" lift
Reactions: Foothills Phil
Wow, Marty is offering blessings now?
Is he also selling indulgences?
Reactions: hogjowl
Larry will the higher amps 10 vs 13 affect the machine in any way? Causing it to shut down? It's one of those 10 gallon castex walk behinds. 3 stage vac and a 100 psi pump.
I will use it to rinse those areas like hallways deep inside a building where I can't get to with my TM. And have bonnet cleaned them for years. Just a rinsing machine probably only using a diluted vinegar solution so as to NOT plug up the jets if left unused for a time. I call it my "Rinse and Clean" method to remove those ENCAPSULATION scampoo RESIDUES. Forget all that BS about being able to vacuum that crap out.
Reactions: Jimmy L
I think the more powerful vac will make a new machine out of it.
I wouldn't worry about the amp draw in your Castex.
