RO water
RO technology has advanced a lot in the last few years due wider usage in many applications. . . .
Membranes are more durable, have less waste water, and last longer.
Lance has stated his last 3 years or so.
Only maintenance is to change the prefilter (~ every 3 months in our water quality).
Larry post a link to your stand alone unit. I couldn't find it on your site.
Gene
Gene
Gene ;
Here is a photo of the system on our 34 HP TM.
The RO membrane, SS housing, carbon block pre-filter assembly and plumbing would run about $700.
It would also require a 100 PSI pump for filtering.
A complete system like Lance's is slightly over $2100.
Lance Golden
Lance Golden
Does your use a booster pump Larry? What about control of the bypass? Are you using a 4x40? There was a great amount of consideration put into my system...
Reactions: Mike Draper
Lance;
We have different systems.
Ours uses a General Triple Plunger pump system,
with a pressure gauge, flowmeter, and bypass valve.
I think a progressive TM cleaner would do a great job with either RO system.
General plunger pumps generally need a booster Larry. The one I bought from you did.
Scott S.
Scott
so if you generat ro water onsite, do you ever get customers or people who ask if its cleaning product or dirty water leaking from your van?
Scott S.
Scott
must be a huge prefilter, as my unit needs a new filter about once a week. im using the standard 1-5 micron whole house filter in a clear housing. ill post a pic later if i remember.
Lance Golden
Lance Golden
@Scott S. , I use 4x10 3 stage prefiltration...
I run a bypass line to a tree, the grass, or a cleanout... it is just concentrate mineral water... and in reality, it evaporates back where it came from...
Scott ;
Our filter cartridge uses advanced Fibredyne carbon block technology for up to two times the chlorine taste/odor reduction and dirt holding capacity of standard carbon block filters. It also reduces sediment, dirt, sand, rust, limescale, silt, and other particulates.
Filter Specifications:
  • Temp. Range: 40 - 180 F
  • Micron Rating: 5 micron
  • Filter Media: Carbon block
  • Initial Pressure Drop: 2.5 PSI @ 2 GPM
  • Dimensions: 10" length x 4 5/8" diameter (Big Blue/Full Flow)
  • Flow Rate: About 2-3 GPM flow rate depending on specific filter system
  • Filter Life: About 6 months or 25,000 gallons depending on usage and local water quality
  • (We recommend 3 month change for optimum chlorine removal)
Lance Golden
Lance Golden
That's not too bad, Larry.... Mine lasts to 35,000 gallons between changes...
Scott S.
Scott
Ok, well it only takes one customers water well full of clay to ruin that filter. Has it completely clog up my 5 micron filter the other day, 1 job 3hrs, 100 gallons of water.
Sounds like you need a prefilter for your filter.
Lance Golden
Lance Golden
I was talking about the carbon block, which is the 2nd filter, protected by a 5 micron pleated prefilter.
