daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
What is your approach when running a rotary tool?
Do you clean upstairs first then down?
Do you get everything that can't be cleaned with rotary first with wand and then hit with rotary or vice versa?
Do you go back and dry with a wand?
Do you just hack it out and skip corners, tight areas, and under furniture?
Do you hit everything you can with the rotary, and then just go back and dry as good as you can with the rotary?
Just trying to get a feel for what most are doing. I can see that running one really requires two people. It is more work, but I am sold on the benefits. I will only wand clean very lightly soiled carpets from now on. My only problem is I like to keep a fan and 175 on my truck. The RX takes up too much space. If I had to choose one over the other it would be the 175. I still think running a prescrub cleans great as well.
I clean everything first with the rotary and then come back with wand to get tight areas or under furniture. While cleaning with the wand I can dry the carpet out.
