Rubber gym floor mats
Zee
Cleaning Professional
How do you guys normally clean these?
I have done some several years ago with some neutral stuff sprayed down and padded it with Orbot and superzorbs. That was a light quick once over...
I'm sure they could be much better cleaned with a wand low pressure...what do you think?
Hard surface tool? 400-500psi. Neutral cleaner sounds about right
Nate The Great
I'd be really concerned of the carpet under the mats getting wet between the joints IMHO... I know Zalan in on top of his game and a smart guy, so no doubt he'll use common sense...
If what you did worked last time, I'd lean more towards that... Less moisture the better...
Reactions: Onfire_02_01
Onfire_02_01
Jeremy Gray
I think you had it the first time. if you need extra agitation you can also agitate with a crb then absorb with the pads
I do those with the DP-420 Hydrowasher.
Run 6000 sq feet of 'em last Saturday.
Piece of cake.
