- Joined
- Oct 6, 2006
- Messages
- 117,397
Pretty darn impressed so far.
5 jobs in has me convinced it cleans deeper than a 175 wand combo for sure.
If the same job were done with the 360 vs the wand/175 combo the 360 job would take about 15 to 20 minutes longer on average, at least that's my guess right now. Trimming out along walls corners and transition areas as well as stair cases.
For that extra rime spent you leave the home owner with more deep crud removed equally as dry carpet. I'll do more testing but I'm gonna predict that rinses don't need to be used in most home scenarios due to the intense flow & agitation, soft water will be all you need. Be prepared to dump more often. Two inches all the way to the head provides much better drying compared to the OG RV.
Perks so far..
Very lightweight
Very easy to use
As good as it gets results
Good alternative for carpal tunnels sufferers.
Well built
Stay tuned.
Perks so far..
Very lightweight
Very easy to use
Well built
Stay tuned.
