- Joined
- Oct 6, 2006
- Messages
- 117,270
Haven't used an RX enough to say.
I'd bet it cleans and dries better though.
Less weight, le$$.
Less weight, le$$.
HARPER said:Mikey P said:that Pwrfligt tool is worthless.
Listen to mikeY....Dan.... :!:
I own one ....they are out-dated....& worthless....![]()
:roll: :roll: :roll:
randy said:HARPER said:Mikey P said:that Pwrfligt tool is worthless.
LOL, Harper you actually bought one of those.![]()
So did I. Back in the pre-glide years around 1993, it seemed like a decent idea. What a worthless piece of junk, laughably so.
Mikey P said:The Original RV did the same this if I remember correctly.
Sort of ties the yarns in knots, creating low areas that create shadows... Right?
mikey, how do you think this rotovac would work on a smaller machine??
I am shopping for an RX-20 - somewhat. Trying to make life a little easier when ever I can. I have talked to Les and Harper. Both have been a great help. Doing a search on the board on the RX I find posts from one end of the spectrum to the other on it's performance and usability. Since I have never used one I am a leery of purchasing one and having it sit. I know I am high jacking this RV360i topic (sorry) but more opinions from those who have owned an RX would be appreciated. I have not run a RV360i either but it just looks a little fragile to me. Time will tell if it can stand up to extreme heat, pressure and vacuum.TimP said:I've had trouble getting my rx-20 to even spin on some very dense and thick cut pile carpet. Also on some loop pile carpet I've had it not be able to spin right, it would hop all over the place in both instances.
I'm sure the rotovac would be more limited in those circumstances due to less weight. But it does sound like it's a cool tool to have in the truck because it is lighter. Lately since I've been working so much I've been running the RX more often since it's easier on the body. One thing I've noticed is that it does out clean a wand by itself. My cds has no trouble with the RX and leaving the carpet too wet either, I run 400-500 psi with it too and 06 flow. I also don't do extra dry passes with it....all wet passes.
Mikey P said:Used it again on a Italian Restaurant loaded with olive oil and Vino.
We've cleaned this place a dozen time. Almost always have to pre spray, scrub and rinse some areas twice in the past.
The guys used the I this time and were blown away with how easy it came clean this time.
The owner even took note and commented about it when I called to arrange for a blow pick up.
The water that came out of the waste was beyond black
Cant say enough good things about this baby. :!: :!: :!: :!: :mrgreen: :mrgreen: :mrgreen: :!: :!: :!:
Coolest piece of equipment to hit this industry in a long time.
