- Joined
- Jun 13, 2008
- Messages
- 19,945
- Name
- Brian Robison
Harper is that guy who doesn't agree with anyone.....except for maybe this post.
Brian R said:Harper is that guy who doesn't agree with anyone.....except for maybe this post.
HARPER said:Soak your pad in isopropyl alcohol...and spin away..... :shock:
danielc said:HARPER said:Soak your pad in isopropyl alcohol...and spin away..... :shock:
I'll pass.
I'm going with the NCL all in one encapsulating cleaner.
If it doesn't work, I will return with the Release-it.
It should work. NCL makes some really good products.
I think they make the best wood floor cleaner.
HARPER said:danielc said:HARPER said:DAN,
Wouldn't it make sense for you to POST PAD this type of JOB... :?:
It take 10min"s ..to have a helper running a 175 with a pad behind you... !gotcha!
NOW you have a RE-DUE... :roll:
What does that RESERVICE cost you....![]()
ps Has it ever occured to you cleaning GurU'S...that the GLIDES we now use on
commercial carpets...DO NOT FLUSH THE SAME AMOUT OF SOIL...as an un-glided wand.!
ohhhhh I would call bull shit on this....more so with an rx glided vs non-glided
Other than a little "wand-chatter" and a little more strength...! Your results will be better.!
"Just run your RX & post pad"....You will SLEEP better @ night... !gotcha!
We did post pad about 50 percent of the areas with cotton bonnets. I have done this place several times.
From now on we will steam clean, apply encap detergent, and then post pad.
Just padding alone did not work.
In fact just scrubbing and running a bonnet would likely yeild better results, but I can't do it.
CONGRADULATION'S.... :!: :!: :!: :!: :!: :!:
"DaH"... :roll:
You have just FALLEN into the category of...."POOR CHEMISTRY & FLAWED SKILL'S"...![]()
danielc said:Also I run unglided on about 90 percent of the jobs I do. There is no comparison in how much deeper it cleans.
Brian we will be following in your footsteps on some of the rentals with poly carpets.
I get it.
HARPER said:Dave Yoakum said:Someone leave the door to the old folks home unlocked again?
What ranting!!
" In my day bla.. bla... bla......"
The nice security men will walk you back to your room Mr Harper and give you a pill for your nerves.
You won't even remember strolling away as you slip back to never never land.
REALLY.............."pHucKtarD".... :roll: :roll: :roll:
Thank goodness...you didn't AGREE with me in this post... !dork!
I WOULD HAVE LOST ...any remaining CredIbIlitY....![]()
Good Luck FisHinG... !gotcha!
I hear you are QUITE THE "GraPPleR fIsHerMaN"....in your custy's BATHTUB....![]()
