I dont remember which, and to lazy to go look...
its a 100 psi pump...
anyway it started cutting out, and you would have to smack the machine to get it going (this is my prespray machine)
So i finally took it out...and apart....cleaned it out, put a little lube on it, test...test...test again, it works fine....out of the machine and in.....
Now its cutting out again...this time more....
I had one do it before and it was the Carbon brushes worn down and had build up...cleaned it and worked fine...but they were WAY worn.....
Near as i can tell not a problem here...
when it pumps its still strong.....it just needs a good whack...and getting worse
WTF is going on here??
