We only use Stainless for blower silencers.
I've seen too many rust clogged OEM silencers to rely on them any longer.
http://www.cobbcarpet.com/zen/index...sult&search_in_description=1&keyword=silencer
Larry
Hey bob! Bring on the freebie.....I will at least bring lunch.....send me a number....
Hi Larry do you make one of those for the Everest 650 CFM?
I bet a dollar to a doughnut that it's a a 3-inch FloMaster off-set, great little silencer.
You awake yet Bob?
ya those 3' Flowmasters worked good if you welded up one end shut and cut a 3' hole in the side...no straight thu sound..but ya HAD to have TWO....to knock the top AND bottom off the sound sine wave..
We tested many different silencer db levels . . . . View attachment 5223
before deciding on the stainless models we use now.
FloMaster did not make the cut.
Larry
I have spent 1000 $$ over the past year trying to find blower silencers for my 2 naamco's....been thru 3 and they are some kinda messed up loud mufflers.....don't work...I don't trust any thing that even looks like a muffler...I have 4.5 blowersEven without knowing how your machine is configured/installed/vented I can tell you with confidence that a double walled dual chamber blower silencer will give you the maximum suppression you may be looking for. I've messed with this for almost 10 years with 3 universal silencers and probably a dozen automotive mufflers (funny how truckmount manufacturers call them silencers). If I state here the actual decibel numbers comparing silencers with mufflers the b.s. around here will stack up faster then can be shoveled. However I will say look at your configuration with all its measurements and attempt to find a Universal brand blower silencer that fits the cfm flow and inlet/outlet pipe dimentions.
