For as long as I've had this van the temp doesn't go above about 160-170 degrees. I'm talking about the engine coolant temp and cleaning water temp both read about the same. Once it gets up to that temp it stays there constantly with very little fluctuation.
Back when I first got the van I assumed it must be a thermostat stuck open so I installed a 205 degree stat but it made no change.
I've just been living with it but now I have a small coolant leak so while I'm fixing this leak I'm taking the opportunity to revisit the temp issues and it dawned on me that maybe the problem is the stat was installed backwards?
I know how to install one normally but I don't know if it's different on the direct drive? The first two pictures is how it would normally be installed depending on if it goes before or after the return line that runs back to the machine? When I got the van it was installed like the first picture.
I'm also open to other ideas that could be causing the lower temps? Yes, I have bled the heat exchanges and descaled but I never thought that was the issue anyway seeing as how my engine is also running cooler than it should.
Ps It's a white magic pro-1200 if that matters
Pss I just dropped the stat in boiling water and it did open.
