Slop and Gobble
Deke Hatley
Clovis, NM
Deke Hatley
So, I found a really good deal on some Judson Slop and Gobble. Got 4 #8 jugs for $33 each on Ebay. I've always heard how great this stuff is so I'm exited to give it a try Monday when I get back to work. Anyway, the jug says 1 oz per gallon but it does'nt specify a difference for a pump up sprayer or an inline sprayer. Anybody know what the proper amount is for a Hydroforce. Surely it can't be just 1 oz?
Village Idiot
5oz or so in a 4:1 HF
I'd start with less
Reactions: Deke Hatley
Deke Hatley
Clovis, NM
Deke Hatley
I'd start with less
Is the little scoop that comes with it a 1/2 ounce or 1 ounce?
Redding
Its true. I use it all the time. 1oz per gallon.
Deke Hatley
Clovis, NM
Deke Hatley
Do you use a 5 qt or 7qt Hf? I use a 7 qt with 8:1 tip. I know i get 7 gallons out of it. So I add 7oz of S&G.
You need to do a bucket test with your HF and know this stuff.
mines a 5 qt with the 8:1 tip. So it looks like 5 ounces for mine.
Fill your hydraforce with water all the way, hook it up to your truckmoynt running at your normal operating pre-spraying pressure.. and keep filling measured buckets until the hydroforce is empty.. chances are it's going to make 8 to 9 gallons from there you can add 1 to 2 ounces per gallon of your slop and gobble but that little tiny scoop which is probably less than a half an ounce is unrealistic especially if you have hard water
Deke Hatley
Clovis, NM
Deke Hatley
Ok I'll give that a try thanks.
Reactions: Nomad74
Village Idiot
Serious questions..........
Why are you buying who knows how old prespray from a guy that mainly sells hubcaps on ebay?
Acp
Seattle
Bjorn Marshall
careful buying pre spray from 3rd parties for a discount... how easily could I buy a ton of bio break and cut it then sell at a discount? Those jars arent even sealed
Deke Hatley
Clovis, NM
Deke Hatley
Well, I've been wanting to try it for awhile but because of Judson's shipping cost on top of the cost of the chemical itself it's around $80 for 1 jug. So I figured as cheap as I got it off Ebay it was worth a shot. I guess if I got jipped it's not that big of a loss.
Deke Hatley
Clovis, NM
Deke Hatley
Guess I'll find out tomorrow when I try it. Worse case scenerio I'm only out like $150
Deke Hatley
Clovis, NM
Deke Hatley
Does it look like some madman pounded it into the jug with a mallet?
Ha! I saw that video too. Les was pissed. But yes it does all 4 jars are packed tighter than heck. Had to use a big long screw driver to stick into it to find the little scoop. Also for jars that are supposed to be #8 they seem heavier than that. I may have gotten ripped off but I figured it was worth the risk if that stuff works as good as everybody says it does.
Redding
Order through Sunbelt USA. Free shipping over $350
