sam miller said:it would be intresting to know if the barkeepers soap would take a out acid stains on the I might but some stainless steal etch with acid cleaner and see!
C Pennington said:[quote="sam miller":2aewv775]it would be intresting to know if the barkeepers soap would take a out acid stains on the I might but some stainless steal etch with acid cleaner and see!
Gary T said:Easy fix. The stainless isn't etched, it is oxidized(basically rusted). Barkeepers friend and some fine and med steel wool. Start with just a little drop of friend and go with grain with med steel wool. Switch to fine with another dab of BKF and finish it out.
There is absolutely no reason why you should ever have to replace any stainless cause you got some cleaner or acid on it. The only exception is the coated crap. Buy one of those home kits from scratch-b-gone. They work if you are not a total moron. I have made a ton of money using that goofy little kit. I have also been reconditioning stainless grills for several years now, before those kits came out.
Don't let them f*%k with you. All stainless can be repaired except the coated crap.
C Pennington said:[quote="sam miller":1h1n4td3]it would be intresting to know if the barkeepers soap would take a out acid stains on the I might but some stainless steal etch with acid cleaner and see!
