KevinL
Anybody know the difference? Is it just the 3rd bottle that you apply afterward? I've never stuck around long enough to apply the CCS or whatever it is.
Citric acid should not be used on carpet !!Hoody said:It only says to mix the product first - carefully read the directions. It would pointless to try and stabilize the colors/dyes AFTER you've altered them with a strong oxidizer. Make sure you also flush/rinse the area well afterward, citric acid(the CSS) tends to leave a sticky residue even if it is an acid you can/will get re-soiling issues.
And yes you are correct about applying it last as well, that is to neutralize the oxidizer after you remove the stain.
Here are the directionsLook at steps 4 and 5)
STAIN MAGIC FOR WOOL
Description:
Stain Magic for WOOL is formulated specifically to remove organic stains such as coffee, tea, wine, urine, plant stains, etc from natural fibers such as wool and cotton.
Natural fibers are easily damaged. Be sure to test your procedure in an inconspicuous spot for suitability before use.
