Starting the machine after a lay off
Utah
So i start it up after almost a 2 week lay off....mind you i ran vinegar through it to help descale it...and i have a black pipe heater..no vinegar in the steel coil though...
non the less the amount of shit that peeled out of there was crazy...made my flow switch stick open for a while...clogged up the back side of my quick connect...
if nothing else maybe next time i run water through it 3 times a week next time i have a big lull
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Pick up some Steamway descaler from Olson. Not the Prochem stuff its not as good. Utah sucks bad for hard water.
XTREME1
Ma
Greg Crowley
take an old solution hose cut it to about 10 ft hook it up and run it a 25-30 psi for a few minutes next time
Utah
funny Drapes....cant all be as wealthy as you !gotcha! !gotcha! !gotcha! !gotcha!
My guy told what you were charging :shock: :shock: :shock: :shock:
hehe
Crowly, i do have one....but if the chunks are bigger then say sand...it fooks up the BACK SIDE of the connect.....ill try to remember to take a pic next time it does it
