Starting the machine after a lay off
So i start it up after almost a 2 week lay off....mind you i ran vinegar through it to help descale it...and i have a black pipe heater..no vinegar in the steel coil though...
non the less the amount of shit that peeled out of there was crazy...made my flow switch stick open for a while...clogged up the back side of my quick connect...
if nothing else maybe next time i run water through it 3 times a week next time i have a big lull
Hoody
Steven Hoodlebrink
Years of Experience
20
Pick up some Steamway descaler from Olson. Not the Prochem stuff its not as good. Utah sucks bad for hard water.
X
XTREME1
take an old solution hose cut it to about 10 ft hook it up and run it a 25-30 psi for a few minutes next time
M
Mike Draper
or just run soft water and you will never have these problems :lol:
funny Drapes....cant all be as wealthy as you !gotcha! !gotcha! !gotcha! !gotcha!
My guy told what you were charging :shock: :shock: :shock: :shock:
hehe
Crowly, i do have one....but if the chunks are bigger then say sand...it fooks up the BACK SIDE of the connect.....ill try to remember to take a pic next time it does it
M
Mike Draper
can you belive that!!!!! 3000 sq. ft. for free. I'm still pissed about it!!!
