- Joined
- Aug 19, 2013
- Messages
- 7,001
- Name
- John Stewart
Damn i wish i had taken photos.
Anyway the 1st cushion just wasnt cleaning quickly enough and good enough for my greed OCD personality. So I took the cushions back to my "laboratory" to test a variety ways of cleaning them. Each way had its own pros n cons.
1) spray with high pH prespray, scrub and let it dwell overnight, then rinse extract clean the normal way. -- very time and energy-consuming.
2. Spray with high pH scrub put covers in washing machine and wash several times.. - getting them off and on the cushions with a pain in the ass, as the foam was very stiff and would not compress enough when I put them in a vacuum bag system. But the cleaning results were outstanding.
3. Keep the covers on the cushions. Pre spray with high pH, scrub, wash with a 1800 pressure washer. Put in vacuum bag system to Aid in water removal.- this was the easiest and less time-consuming system. That's results slightly less than option number 2 but still very good.
Lesson learned- this was not typical upholstery cleaning and I will charge one and a half to two times above our normal rate for the service.
