rwcarpet
Well, I got complacent with my Genesis utilizing the APO as a "right arm" to my daily cleaning. Well.....the APO system isn't functioning as of last week, mainly cause it keeps eating up impellers. And that is because the prime system, for some reason, has decided not to actuate ever time when the pump turns on. And without a water prime, it will not draw from the waste tank. It's a 10 year old TM, and I guess it's ready to take a break. so......
On ebery job, I have to arrive with an empty tank, pull out an extra 50 foot of 2" hose just for the waste drain, and hope I can find some place on every job to dump ........respectfully. I have to keep going out to the truck every 15 mins or so to check and drain the tank. It's adding 1/2 hour to every job.
I'm going to try a 12 volt impeller pump this weekend to see if it will draw from the tank. I guess a little slowing down is needed now and then.....
