I used 4 different pre-sprays on a lot of real dirty halls and stairs today. I normally use Powerburst But I thought I would try some of the other stuff in my van. This was all sprayed with a plug in sprayer to keep it real.
First off was Slopin gobble: Cleaned real well, and I was impressed how low the dilution was. Very comparable to Powerburst at this time, but I will have to test it side by side on my nasty rentals.
Second was Powerburst: Cleaned like always and could tell no difference to S&G on this particular job. I did notice that I had ALOT of suds(when dumping) mixing at 4oz per gal. rtu though(seems to be more then necessary) . I usually use a Hydroforce no tip and mix 12 oz. in a 2 1/2 gallon jug to fill my HF. Normally I would boost with citrus also, so??
Third off was Fission: Didn't seem to clean as well as the other two.. I would say a couple steps under Ultra pak, nice fragrance though..
Forth was Prochems "Heavy Artillery": First off 16oz per gallon for a pump up or batt. sprayer is ridiculous!! I really didn't think the cleaning ability was all that great either.
