The 175 humpety bumpety...
Bob Foster
How do you get the 175 to rotate smoothy on my little machine? I have the pad on straight but it still wants to humpety bumpety a bit.
Love to get one of those 360i's.
Jim Williams
Bynum N.C.
Jim Williams
Are you saturating the pad or bonnet with prespray first? Sounds like you might have too much friction.
Benton KY USA
Tip it back, power off, and carefully rotate the drive block by hand. Watch for "wobble" because you likely have a high spot or loose clutch plate (the little metal mounting plate with three spokes).
Art Kelley
Clawson,mi
I've never used a pad, always a brush, so I don't have that issue with the 175. It seems retarded to use something you have to throw away after a few days or weeks when a single brush will last for many years and do the same thing.
Bob Foster
More slippery than goose shit on a wet lawn...
Ryan
Readjust your handle, sometimes they just do that.... might look into a new pad driver like Lee suggested.
What brand of machine are you using and which pads?
Bob Foster
Chads
dont lock the handle down just let or maybee its the otherway around. but give it a shot I think i tried that a time before with good results.
Benton KY USA
I've had several PH buffers identical to that. The little ones are much less stable than the bigger heavier ones. Don't run it without locking the handle or you will regret the experience.
Johnny
La-Z-Boy
Johnny
Try Tuway pads from Cobb's or CCS. (Don't remember where I got mine, they've lasted me at least five-six years.) Will last at least a hundred jobs each and scrub better than a brush, imho.
Bob Foster
All good info guys. I think I will throw one of those tuways I got from Clark Lancaster and try it. I think the small machine stability makes sense. I don't have a problem with my bigger Clarke machine.
John Watson
Bobby, No wonder you are having rocking problems, you seen the size of those Canadian Geese turds??? Them suckers are HUMUNGUS. Couple of years ago they had to exterminate abunch of them cause they wouldn't go home... and they were poluting our parks and beaches..Kids were tripping over them.
I think Lee is right, the little guy doesn't have the weight or cover the area that a bigger machine does and so it can be a little bumpier.
We have a small Hild that size and it can bump a bit, on uneven concrete.
Ryan
I'm not familar with those... but like I said some scrubbers just do that...
Mytee's new ones are nice :mrgreen:
