bensurdi
All right guys, we've all been doing this for years and have probably tested everything on the market... What do you think works the absolute best for sub-surface urine treatments?
Jimmy L said:I kind of agree Scott but is there any enzyme product out there that is NOT sold as a rtu gallon of product?
I think it gets very expensive to go that route.
Give me a enzyme for pet urine that you add 2-4 oz per gallon.
Storm Warning said:Hell I clicked on this thread because I thought you were stating which one.
We've tried a bunch of them and are currently using OSR CTI's stuff and it works pretty well. We also have jar of VacAway's PeeRadicator we have not tried yet but have heard nothing but great reviews.
scottw said:You can use any enzyme product with living enzymes as a concentrate if you wish. The bacteria produces the enzymes. Enzymes digest the food source which the bacteria use to grow. The bacteria grow and multiply and so forth. @ bacteria make 4 , 4 make 8, 8 make 16 ....
The more concentrated the product, the more bacteria that are present, the faster that meal of urine gets digested. So most manufacturers tell you to use the product straight to get the maximum concentration and save time. But you can still add water and dilute the product. The process simply proceeds faster with 1 million bacteria than with 100,000.
Each cycle of reproduction takes roughly 20 minutes. (That depends upon the exact strain of bacteria, temperatures and so forth.) Suppose you took a product that was supposed to be used straight and diluted with 8 parts water. After about an hour of activity, it would be up to the original strength. So, it takes an hour longer. .
joey895 said:My understanding is that with these products you have to put enough down to make contact with the total amount of urine in the carpet. For example I did a job the other day that had three rooms with pretty severe contamination. The carpet looked good but the odor was overwhelming and my moisture detector went crazy. Anyway I used a total of about 10-12 gallons of product poured from a bucket directly onto the contaminated areas, let it sit, and then extracted with my water claw, then pre-treated and cleaned as normal.
Using one of the ready to use products I would have spent $250+ in product alone, I figure I must be missing something. As it stands I used about $40 or so of product.
This leads me to something I've been wondering a long time. How is a syringe used to inject the deodorizer into the padding? It seems you would never be able to get enough of the product to the padding using a syringe unless because you are using the enzymes you don't have to actually saturate the pad? Do the enzymes spread and do their thing? If you could use a lot less moisture I could definitely see the benefit there.
I not sure if any of that makes any sense, if not let me know and I'll try to clarify.
thanks Joey
ACE said:Best enzyme treatment is Masterblend's Urinelock.
Best Oxidizer is OSR's New formula
Stay away from interlinks crap it has too much precarb and will bleach some carpet. It sucks as bad as their customer service .
Are you saying that Jimmy could just buy a quart of bio charge and pee in the bottle and have a 50 gallon barrel of the product by the next day?
