360...
smaller version...2195
Larger...2495
Trex...2495
Hoss...2995
RX-20...3995
The new 360 put teflon back on due to the head size....still has the 4 vacs, and 4 jets...2 longer, 2 shorter....pretty much the same as the smaller one from what i could tell
Trex...1st off (and this is meant to be nice but firm) John, dont get mad when someone tells you there are flaws...EVERY MACHINE, goes through changes and some better then others...(think rx with the stupid shoes and jets) but even after 30ish yrs they still tweak things...
so then....Motor...yup this will need to be addressed...dunno if it was the fact of using the gennies from the trucks or what..but on thicker carpet it had a time getting going (think 175 on a shitty circuit) And while the next 2 things are from what someone told me(as i was inside talking when they picked up...hence not many samples
) and I would concur with this one, as i used a 175 with a solid handle vs a plastic....uh its going to break..seemed it had cracked i heard...and the carbon fiber pole was looking a bit weak... Also the swoops were backwards
I didnt see it, just told to me while chatting about it....cant believe i missed that
but it seems to be a solid start to another choice of tools...
Hoss, has made some adjustments (see john EVERYONE doesnt get it right off the bat)
all 5 bars are full length....took out the jetting disks in favor of one of those adjustable needle valves Jim talked about...so adjusment on the fly....made a new uhhh "cap" though not clear anymore (its blueish) suppose to be stronger, and they found out why they had stems breaking...bad batch not centered i think it was... Moved in the support bar on the back, so can roll up or down stairs better.. took off the handle "guard" and put in a flip "switch" that you need to just flip out of the way to pull the trigger...very easy.. Made the handles bend in by 3" I heard.... Fixed the rattle of the wheels...
Damn do i pay attention or what
Rx steady eddy here...though he hinted at a pretty big change up...or possible new one....dunno....due in the fall i think it was....
Did all that make better sense???
