the ultimate way to clean trashed carpet
Trip Moses
IMOL
Trip Moses
Seems like a waste of pads. Maybe a carpet brush or a CRB instead.
Jeff T
When you can knock on carpet like wood, a CRB does NOTHING....
I know this, cause I clean 2 different pubs...
One is a blue collar, logging, hillbilly bar.... I used my 175 with a red pad to cut through the gunk, and blasted it @ 750PSI, and Max heat for rinse...
When I presprayed, I may as well have been spraying a wood floor...
It was bouncing up, and sitting on top....
I could see my OP with a Gorilla pad being very effective.... only difference? I’d be tank feeding a nuclear prespray...
Reactions: Living The Dream
You can run whatever pH 14 prespray you want to run through there but it won't "release" the soil as quickly as a neutral pH encap will for whatever ungodly reason...
Jeff T
You can run whatever pH 14 prespray you want to run through there but it won't "release" the soil as quickly as a neutral pH end cap will for whatever ungodly reason...
Interesting. I’ll have to try that...
hmmm
and you'd speculate the reason is the poly in the soap?
as that wouldn't seem the only difference right?
I didn't watch the vid.
I think I got it though, aggressive pad scrub followed by flush/rinse extract
....how revolOOshunary
oh, and CRB's ain't squat for scrubbing soil off carpet.
One step above a grande grOOmer is all.
Reactions: hogjowl
Jeff T
This statement is false. I use a CRB on a fairly regular basis, and not only does it help to remove ground in soil, it lifts the fibres up, and scrubs the prespray in. The end result is FAR superior to using a grandi groomer, and wand...
This machine, like all others, has its place in our industry...
Have you owned a CRB Larry?
A wheels up pos
My sentiments exactly, but I pull a trailer with a ramp. Oh, and a 10 and 15 crb if Cimex not needed. But my truckmount isn’t big enough for the big zippidy do da, so 13 for me🤷🏼‍♂️
Reactions: hogjowl
Mark now knows as I do and the rest of you enlightened or soon to be enlightened that if he had had about 50 pads of blue and another 50 of the white she could have made that carpet look better dry quicker and stayed cleaner longer without a truck mount..
But would probably still be there...lol
always been the case.
in the olden dayz when it was cotton, a pad did a great job ....for 1 sq yrd
agree .
it's great for fur in doggie houses
But my philosophy has always been, if I have to bring in additional equipment, I'm going to by-pass anything less and bring it what will make it look best be it 20 pounds or a 100
if you don't believe it's a rotary, Cimex or Opie.
Try this simple, easy test next time both tools are in a building;
Spray your pre-spray de jour
Run your CRB across a soiled traffic lane.
Run any ole bonnet or pad with any ole rotoscrub or ox-galating MoSheen right next to it.
Lemmie know if you can tell the difference
Planetary action is difficult to beat for agitation.
semantics
it's still a rotoscrub, just easier and more idiot proof than a rotary or rotary with the shakes*
*other than demos, I've never run a wheels down Opie ...so I really don't know if it's as idiot proof and easy as a 'mex
semantics
Easier
Reactions: Dolly Llama
rick imby
Rick
John G would be really proud of Mikey and Sager comments in the video and this thread.... Kinda different tune from five years ago...
