Thinking of Cimexing, if that's a word.
steamron
Northeastern PA
Ron
I usually do this large carpeted room every 6 months to a year, but during Covid they replaced just about the entire carpeted area's.
This is only 1.5 years old,
My TM and Zipper will take 3X longer and a lot of water.
Check out the pics, you can see how it's not even touched under a table and cart.
Reactions: Kenny Hayes
View attachment 121908 View attachment 121909
Cimex will do a great job as will a Phoenix or similar.
encapman
St Petersburg, FL
Rick Gelinas
You should be fine hitting that carpet with your Cimex. I'd suggest Encap-Clean DS2 and FiberPlus Max pads.
You could also apply Encap-Punch as a pre-spray before you run over it with the Cimex.
Be sure to take some before and after pictures.
You can submit pics on the bottom of the Excellent Supply website and get a $25 discount on Releasit.
Yukon, Oklahoma
I highly disagree! Cimexing (action) is the verb of the noun Cimex. Noun is a person, place, or thing. He should be successful using his Cimex as a noun to scrub that carpet😬
encapman
St Petersburg, FL
Rick Gelinas
I stand corrected. I conferred with my wife. Nancy's my resident grammarian. Although Cimexing could be a noun, in this context you're correct... it's a verb. 🙃
  • Haha
encapman
St Petersburg, FL
Rick Gelinas
I think you're right. 👍
We've got some smart guys here. I had to look that one up:
"A gerund is the noun form of a verb that ends in -ing. For example, playing, dancing, eating."
Yukon, Oklahoma
Nevertheless, using the Cimex on that carpet is an Excellent ideal. I would do exactly as Rick suggested with Encap Punch and DS2 with gray pads. If there’s additional spots I’d use TOPS spotter. I would do like Mike said, but with an Orbital.
Reactions: encapman
