Curtis Pennington
- Joined
- Jul 12, 2008
- Messages
- 1,537
Dont see it.........after 3 weeks and various capets jobs, no differnce not having another orfice in the middle.....another board myth...LMAO
Mikey P said:center gap?
you mean between the 2 manifolds?
when did this become an issue?
truckmount girl said:You never really notice it until your jets get worn out. When your ti wand streaks, you know it's time to change the jets.
Take care,
Lisa
SRI Cleaning said:Do the inner 2 jets have a wider spray pattern?
Waldo said:
meAt said:Waldo said:
operator error no doubt.... :roll: :roll:
BTW, right you are, Lisa.
I went out and found my stock Ti jets.... 8001 center jets
dealtimeman said:are you sure you are properly using your equipment? :shock:
and now you cant get edges very well huh?You should be over lapping anyway lazy assadmiralclean said:It's not streaks that I'm talking about. It's overspray ... and I know that my two Titaniums and one Greenglide with 110's all the way across can not possibly be the only three wands in the world that experience it.
I don't like those wet lines. You can't see it on most carpets, but it's there. But just watch when you clean a commercial carpet and you will see it. Most folks probably do a dry pass and then it's not an issue, but on jobs that have all the time in the world to dry (like rentals), I don't want to HAVE to do an extra drying pass.
So I went to 8002's on the two outside jets.
Greenie said:You know, when I see dumbass post, i always thought it was a bama thing, now I think it's a southern thing.
There is a large GAP in the center of the Ti wand where the water is significantly reduced you morons, but thankfully the jet extenders and the wide angle spray jets help to compensate.
at least say thank you...sheesh.
And no dry stroke? I'm ignoring that one, reference above bama comment.
