Top down dryers......
kmdineen
Kevin Dineen
I dry the carpet and pad "in place" when ever possible. What I find during my pre inspection determines how I will proceed. I always lift a corner of the carpet to inspect the pad and look under the pad to examine the floor. Finished hard wood floors, covered by carpet and pad are not a candidate for in place drying.
Common sense is also a factor, the amount of water, how long has it been wet, did water pass from one level to another through the floor?
I use a hydrosenser to determine if the carpet and pad are dry, a surveymaster for sheetrock and moldings and a hammer probe with insulated pins attached to my surveymaster to check floors. I assume all sub floors are double plywood.
KeithCo
Keith Collins
Spread the word, Fred.
You're exactly right. Not all construction is conventional.
The weird stuff we have found during demo is amazing.
