- Joined
- Jun 29, 2015
- Messages
- 7,504
- Name
- Stephen
trinityopsystems.com
I don't know why you'd want to say that when it's more than likely going to make a perfectly good leave behind spotter for the homeowners..Should read 'For Professional Use Only' with all the precautions listed.
I was looking for the sds sheet. I don't see it on their website.
because that's when you find out its only ground up Fels.I was looking for the sds sheet. I don't see it on their website.
I poured two big puddles of it in my highest traffic lanes where my dog lays and I'm going to watch the re-soiling
I used to have a spotter locally that seems similar. It contained some kind of banana smelling acetate. Worked great. Hopefully we get some distributoship in Canada.because that's when you find out its only ground up Fels.
The label states that. Second line from the bottom.
Maybe not so good for the pup.
Skinwhere my dog lays
Has anyone noticed a lot of foaming when used on carpet spotting. . High ph works great but be careful pay attention. jz
Thank you just spot clean with water extraction OK .Remember, this product is designed to be used along with any VLM method, so:
- less is more
- once the offending spot is gone, a light rinse is all that's needed with HWE
- that foamy white look goes away in minutes
- Ive been using Prochem AFB and have not had foam issues in my HWE equipment
I just stand on the spot with a towel and soak up the excess. I had good results with it. I need to post the video still. I’ll get off my ass.
Hang on whilst I go run my head into a doorpost first.Call me and give me your CC info
Sorry. What’s AFR
All Fiber RinseWhats an AFR?
Amyl acetate smells like bananas. It's the key ingredient in non-acetone nail polish remover.I used to have a spotter locally that seems similar. It contained some kind of banana smelling acetate. Worked great. Hopefully we get some distributoship in Canada.
