John Olson
Here is the wind speed of the Triad
Here is the wind speed of the X3 on High (4 amps)
:shock:Our testing places the Triad at best 810 CFM verses the Typhoon at 1066 CFM. At 5, 10 and 15 feet from the fan at surface level the Typhoon is almost twice the CFM of the Triad.
Doc Holliday said::shock:Our testing places the Triad at best 810 CFM verses the Typhoon at 1066 CFM. At 5, 10 and 15 feet from the fan at surface level the Typhoon is almost twice the CFM of the Triad.
dgardner said:John, the air balance people know that velocity is not consistent across the face of the opening, so when they are measuring CFM they take several readings (called a 'traverse') and average the readings together.
It would be interesting to see a traverse of 5 or so points across the face of each fan to get an accurate picture of true airflow.
John Olson" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">John Olson said:Here is the wind speed of the Triad
Shawn Forsythe said:dgardner said:John, the air balance people know that velocity is not consistent across the face of the opening, so when they are measuring CFM they take several readings (called a 'traverse') and average the readings together.
A very important point that can't be overlooked. The Triad design is especially prone to varied velocity across the opening. Good post, Dan.
John Olson" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">John Olson said:Thats beyond what I am capable of doing. I only have my little wind speed indicator. I am about to post pictures of readings across the face of each and at 3'. Interesting stuff.
Doc Holliday said:Isn't the Sahara around 1150 CFM's?
LOLDoctor, Doctor, Mr.MD, I thinks 1150 is RPMs. 6 pole motors. probably about 2500 CFM rated if a 10" fan
