theden said:Do you think using a 175 to pre scrub then using a 100 or 200psi portable to rinse vs. not using a 175 to pre scrub but a TM to clean with, what would do the better job? Assume pre-vac in both cases.
meAt said:theden said:Do you think using a 175 to pre scrub then using a 100 or 200psi portable to rinse vs. not using a 175 to pre scrub but a TM to clean with, what would do the better job? Assume pre-vac in both cases.
if a dude roto scrubs and porty extracts, he'll be doing a better job than 98% of the squirt and suck TM dudes.
and better than 91.7% of the pre-spray and rinse TM dudes
KevinL said:What kind of calculator do you use??
meAt said:KevinL said:What kind of calculator do you use??
my own "well formulated" one, of coarse :mrgreen:
Eric Valentine said:I am a roto scrub and porty extract guy, and regularly get compliments that I did better than the last 3-4 prespray and suck TM guys.
The perfect answer to this question. You can do the same job with a porty that you can do with the TM. It is just MUCH slower and MUCH more workMikey P said:How hard do you want to work and how much time do you want to waste?
