Jimmy, I have the TF3500.
Here's a link and a bit of info about it.
http://www.masterblend.net/index.php?op ... &Itemid=80
The TruckForce 3500 features maximum vacuum performance for carpet and upholstery cleaning.
· Three two-stage vacuum motors, in-series, provide over 190" of water lift (14" of mercury) and 100 CFM.
· All vacuum connections and piping are 2" in diameter to maximize airflow and produce fast drying times with 100 feet, or more, of 1-1/2" vacuum hose.
· Each vacuum motor can be independently operated, so that single or dual vacuum operation is always available for cleaning upholstery and delicate fabrics.
· The 1.5 gpm 500 PSI pump is EASILY adjustable from 50 to 500 PSI by the pressure regulator on the control panel. The pump is powered by a 1/2 horsepower high-efficiency, dual capacitor motor.
All systems are time proven for quality and reliability.
The TruckForce has a 12-month limited warranty against defects in material and workmanship.
The rotationally molded body has a five-year limited warranty.
We are so confident of the quality construction and the use of innovative technology in the TruckForce that we offer a 14-day limited money-back guarantee.
I like it a lot, it has guts.
It is also surprisingly quiet.
There are a few things I am not happy with, but they are minor.
IT IS A MACHINE TO LEAVE IN YOUR VEHICLE.
It is BIG and SOLID.
The positives of this machine far outweigh any negatives in my opinion.
If you want any further critiques, email me.
Ooroo,
:roll:
