Trust the Creator (Judson TM related)
Cleaning Professional
Les knows how to build them.
I just had to learn how to do the maintenance correctly.
I wasn't getting the performance I thought I should from the CanAm, though even at subpar performance it was still giving great results.
I realized I needed to secure the throttle from backing off/relaxing when I gave it full revs. WHen it would back off I would loose a few hundred RPM which made it bog down under load. Now she's full bore with a slight drop.
My heat was off too. I thought it was because of my flow (15), I was barely maintaining 180. So I pulled the boiler ring, cleaned the jet holes, and then CENTERED it. (This is what I think was the main problem before, I had it a little off center)
NOW I'm hitting just under 240F with 15 flow at 600psi and its not even maxed out. Right where Les said it would be.
Thanks Les.
Nate The Great
I do agree, Les is the man!!! Or when you deal with Les, you get more!!! Badabump! shiteatinggrin
