Ultra Adsorb vs Brush Pro Compound
Scott S.
PA
Scott
This Video is of me cleaning my living room with the two compounds. So dry soils for the most part.
a commercial carpet video using these two compounds, is in the works, so stay tuned.
Scott S.
PA
Scott
Did the carpet look noticeably cleaner?
Did you post vac with your "sweeper"?
yes carpet looked like it does even when I hot water extract.
I did post vac the next morning.
here is the pic of the inside of the sweeper bag the next morning.
I'm using a proteam 1500xp at my house.
this pic is of the inside of the bag. The inside of the bag is usually white
Onfire_02_01
Minnesota
Jeremy Gray
I have never used the system so....
1. how is the cost compaired to regular encap or HWE chemicals, I am assuming you have to use A LOT of compound?
2. What do you do with the used compound, garbage or can you compost it?
Scott S.
PA
Scott
1. more chem cost (encap and compound) then hwe but no expensive tm to use, very little water usage compaired to a tm. you can buy a 10 inch crb or a 20 inch for around $2200, you would need a sprayer for the encap, can be pump up ($75)or battery($450-500), or plug in ($350), doesnt matter.
the compound works well on light to medium soil levels, I've never tried to restore a nasty with the compound.
2. the compound is just thrown away, but i would assume you could compost it if you wanted, birds would probably pick out mrs, piffs hair.
Scott S.
PA
Scott
this system works pretty well, i use it a bit on lightly soiled commercial carpets that are 2 stories and up, or apartments that are barely dirty. or when its just too damn cold to drag a ton of stuff threw the snow. (yep Saiger im a pussy when its -10 to -25 degrees. )
Reactions: Kellie Hiler
Shelbyville TN
Dry compounds are helpful when you need to clean an area that has almost continuous traffic such as a 24 hour business. Do it frequently enough that the carpet does not get more than moderate level of soil
The smaller particles in Brush Pro powder should go further for an equal amount of powder. Rather like ULV foffer for guys that are familiar with foggers. Smaller particles means more surface contact area doing the cleaning.
In theory, the smaller particles are also easier to remove from the carpet (by vacuuming or CRB) but I have never tested this idea.
Scott S.
PA
Scott
i actually edited out a part of my video where i wonder that same question.
maybe ill get it and post it up here.
Scott S.
PA
Scott
i have some very thick carpet with a tight pile and thats what spurred my though.
Scott S.
PA
Scott
Here is a good pic for you guys.
side by side adsorb and brush pro, or is it brush pro and adsorb
