Larkin, did you manage to suppress the odor? If you did, I would suggest goingback to your chemical pimp and getting an encap with peroxide.
Make up a quart at double strength, then lightly spritz each wickback and towel it off. Do not wet it, you are polishing the fibers. Then get a fan going to speed up the drying. It will work and the encapsulant will prevent further wicking.
Bridgepoint also has a urine stain remover that has a strong peroxide, spritz, towel and walk away. It works too.
There are other ways and other products, but I'm guessing you are in a hurry and don't have time to order stuff.
