VCT-what is everybody using
Lyman
Johnstown new york
Lyman
I haven't done tile in a long time. Municipal building, new tile installed and never waxed. I used to do 2 coats of sealer and 2 coats of wax. I have a 175 and mop and ringer. I need a low slip finish that looks good and will hold up to no maintenence.
Larry B
Pigeon Forge, TN
Larry Burrell
With the finishes anymore there is no need to use sealer.
4 coats of finish work great
Here is the contact info for Sparten Chemical in your area
Distributor Information Name SOFCO/Div. of Bunzl *Scotia
Address 1 702 Potential Parkway
Scotia
NY
12302
Phone (518)374-7810
Fax (518)374-8437
Larry B
Pigeon Forge, TN
Larry Burrell
Will the floor be getting buffed/burnished or just mopped for nightly maintenance?
If buffing/burnishing will not be done at all or very little then try a product like "I-Shine" or "On an On" they are both 25% solid and hold up well to traffic even without buffing. "On an ON" is harder to strip thean most finishes but it holds up well.
If you will be using a high speed burnisher try something like "TrendSetter" its high gloss and repairs easy with high speed burnishing.
floorguy
Utah
Doug
Ron Lippold said:
concrete seal by ultra chem labs
they also have platiunm just a little more expensive
Oh if i ever found you put that on floors i was to strip, I'D KICK YOU IN THE NADS!!!!!
put finish on vct and put concrete seal ON CONCRETE!!!!!!!!!!!!!!!!
Larry B
Pigeon Forge, TN
Larry Burrell
LOL :lol:
Just dump a gallon of Mop&Glow on the floor :lol:
