water pre-heater idea for air cooled TMs
My rough draft idea for preheating water from plastic fresh water tank.
It uses the exhaust heat with a HX.
It takes water from transfer pump- to HX- out HX and into TM water inlet.
im using QCs for flexibility. as it would need to be moved to close the side door; I realize it will be hot.
I would not recommend this modification in hot weather or low flow water use. I like to use higher flow then my 370 is made for.
A future improvement would be to install it under the van with a custom exhaust system for the TM. and have manual diverter valves when hotter water isn't needed.
this is the other side of HX. wondering if I should remove the back plate.
Are you planning on descaling that before you put it in use?
Why don't the smaller air cooled truckmounts just use a bigger water box, similar to the everest? That should solve the problem.
Prochem Legend for example. That's only a 2-3 gallon container. 5 gallons of preheated water would give plenty of heat. Has that ever been discussed? Or do the tm companies do that to leave room for "upgrading" your machine?
I'm using a higher flow then the 370 is designed for. I don't have an issue IF I used the TM as it is designed for. A larger water box might cause other issue.
I will admit my high flow usage causes my transfer pump sometimes overheat and stop working.
yes I do extra extraction passes, but that isn't enough "Off trigger time" to increase the water temp.
My comment sounded like I was suggesting putting a bigger water box on your new machine. Sorry for the misunderstanding. Your tm doesn't need any modifications like that. I was mainly curious at why those water tanks are so small compared to the bigger ones. Especially when there's a temp. relief valve right on the tank itself.
But back to your little added HX. Are you gonna descale that ugly thing or not?
haha, I admit it needs to be cleaned more-- but I'm not sure if its leak proof yet. im stilling the prototype phase.
