- Joined
- Oct 7, 2006
- Messages
- 1,006
- Name
- Tom Meyer
I found with a 32000 grain it will last 50 hours. Pretty simple
my distributor is pushing this one on me 800 installed...thoughts?
are u doing your own install jim?
Yep...32000.......Kinetico black I like it. I'm sure it's the 32000 grain.
Gene
that black one looks like the abc equipment water softner not a kinetico. and i think the manual says not to store salt in it over night. adding salt everyday semms like a pain.
here is a website with lot of info......http://www.qualitywatertreatment.com/water_softeners.htm
id rather have one with a salt tank. there are lots on ebay just search for fleck.
ok my mistake. pretty good deal then. how long does it take to reach the 50 hour mark?
i bet some dum ass is going to say 50 hours. probably a month or three weeks?
Technically speaking the softener can absorb so many grains of hardness - so if your softener is 32,000 grains and your water hardness is 32 grains you can process 1,000 gallons between recharges, or 2,000 gallons if the water is 16 grains, etc. You can keep track of gallons used, or test the hardness of the output, or do like Jim and pick an easy-to-remember interval. As long as your chosen interval stays under the maximum grains you're golden.ok my mistake. pretty good deal then. how long does it take to reach the 50 hour mark?
where is a pic with opening up the top???
thats the 1 bitch i have with mine, is getting the salt in through the funnel.....kind of a pita....other then that swapping hoses around is no biggy
