.what is the hottest you can get your water and not have trouble maintaining that temp.......
Duane's right.Duane Oxley said:Heat alone means zilch.
Quote temps with a flow rate, or jet size and pressure... and state where the measurement was taken.
230 to 240 at the wand, with the wand keyed continuously, with (2) #3 jets, @ 600 PSI
THAT means something everyone can understand and compare to.
Jim Martin said:.what is the hottest you can get your water and not have trouble maintaining that temp.......
Spanky said:Jim Martin said:.what is the hottest you can get your water and not have trouble maintaining that temp.......
starting with plain ole cold water from the garden hose.. 250 "continuous" flow @ 2.1 gpm
with normal duty cycle on the wand, she'll run hotter than that.
with 06 jetting @450psi I recorded 272 sustained fo-evah.. ATM
normal duty cycle with 06 jetting at any PSI puts it in the "spit 'n rip tear and hisssssss" range
JCoviello said:300* if I want it. Well...it'll cycle from 275-300 with the thermostat. I'm sure without the T-stat it would shoot up to God knows what.
But I normally clean 230-250 as it just gets stupid after that.
This is 250* - set the fire alarm off.
s]http://www.youtube.com/watch?v=Y4gqncGKukQs]
dealtimeman said:with all that steam going into the air how long does it take for your carpets to dry.
Mike Draper said:JCoviello said:300* if I want it. Well...it'll cycle from 275-300 with the thermostat. I'm sure without the T-stat it would shoot up to God knows what.
d]http://www.youtube.com/watch?v=Y4gqncGKukQd]
I think a Greenhorn would put more heat to the carpet, with the jets being closer to the carpet and all. I bet we would all be surprised if we knew how much heat we truly lost between the jets and the carpet.
