I have an Everest and 90 Gal. In my 2500 with no issues.A 100 gallons of water weighs 834 lbs.
can a 3/4 ton handle that much extra weight?
I beg to differ. I bet it's over loaded.I have an Everest and 90 Gal. In my 2500 with no issues.
Tires have a weight limit as well. And might want to beef up the suspension as well.Ahh! no big deal. Just put some new brake pads on the van every year. You'll be good. Don't be a wimp!
GVW is the total fully weight. NOT the Payload amount.
Ford Transit Cargo Van Trims | Curb Weight |
150 | 4,985 - 5,442 lbs. |
250 | 4,985 - 5,740 lbs. |
350 | 4,985 - 5,821 lbs. |
350 HD | 5,743 - 6,053 lbs. |
Curb weight IS NOT the payload weight. It's the weight of the empty vantrue dat, PeeJay
Ford Transit Cargo Van Trims Curb Weight 150 4,985 - 5,442 lbs. 250 4,985 - 5,740 lbs. 350 4,985 - 5,821 lbs. 350 HD 5,743 - 6,053 lbs.
I'm going to presume the high wt variations are are hi-top models
the 250 have a 4000 pound payload capacity
the 350 is less????
looks like a 250 is more than enough.
and the only reason to pay extra for the 350 is the ability to go dually axle and really bump up capacity
I don't know about the inferior brand vans....
I weigh 250lbs....... Not proud.true dat, PeeJay
the 350 is less????
You brought it up, Tubby TommyI weigh 250lbs....... Not proud.
Is that curb weight?I weigh 250lbs....... Not proud.
Its all muscleIs that curb weight?
I know this is peppered with sarcasm…Ahh! no big deal. Just put some new brake pads on the van every year. You'll be good. Don't be a wimp!
Did you get the heavy duty suspension for your Corvette?Its all muscle
Mag rideDid you get the heavy duty suspension for your Corvette?
That's what you get for being stingy with your spare tire.I weigh 250lbs....... Not proud.
Must be 115° there in Redding by now, if you walked a mile a day in your Crocs, should probably lose 5 lb of blubber with each lap..That's what you get for being stingy with your spare tire.
