What is Rick's strongest and most concentrated Pixie Juice?
Zee
DO YOU guys know what that does to carpet?
........me neither that's why I asked. :redface:
Oh man..it does some crazy shiiiit...it comes in contact with some organic matter and two hours later Godzilla emerges...and his entire body is covered with 100% polyester cut pile.
Zee
When I went thru a few cases of HotKnife, was the time I thought about the ammonia...since that HotKnife smells horrible..like ammonia.
And given the fact that Encapuclean o2 is with peroxide I figure an oz wouldn't hurt anything...the same as using the two part stain magic type chems.
Now Godzilla, that's another story...just a side effect of the experiment...
encapman
Rick Gelinas
Mixing ammonia with a peroxide based encap detergent is a BAD idea.
Peroxide based polymers require an acid environment, and ammonia is alkaline.
Zee
Oh well....now we know why the side effects are happening...
:eekk:
Noticeable increase in height.....trouble with the English language?
It's got you
, you have it Zee.....Ofer too! :frown:
Dammit I told you guys to stay away from it!
:p
This just in from Mr. Smith:
Mikey & Dave;
Interesting formulation move . . .
Now we have another producer of Encapsulate products that is now using a film-former.
Film Formers were the original Encap product developed by DuPont.
Formulation is a science.
please please tell me you did not test on that carpet in your showroom.. the only thing that carpet should be use for testing with the NASCAR drag strips and burn outs
8-10 years ago we took over a large account from the then Dupont Flooring Services and they had been using Resistech for several years, it had left the carpet stiff and had a dull soiled look to it.
The facilities manager refused any more low moisture be used in the building, not even from us. We cleaned 9-floors regularly with HWE for several years until the manager moved on to another facility. That was my only experience with it and the results were really poor considering what it looked like once we got it flushed out. Could have been misuse of the product but I would think someone would see how much product was being used over x amount of SQ/FT.
NASCAR has no drag strips. Stock cars run on banked ovals.
You must forgive him, he's a hockey fan.
He doesn't know
NHRA
from NASCAR.
