This topic comes up A LOT. But, has anyone really found a product... lets just say ... a consumer could use,
3% peroxide (grocery/drug store or 20vol clear developer)
There are risks involved on some carpets/rugs , but it's self neutralizing and no harmful/sticky residue
Other than that, they're off to the PetSmart for some over priced squirt bottles of enzyme
Not just for consumers obviously, but is there anything that REALLY works or is every product out there failing to reach this expectation?
not for consumers, unless they have the ability to flood and extract.
But flooding the carpet and pad with
strong oxidizers followed by water claw can fix
many (not all) urine contamination problems
for the pro, the "experience" factor comes into play, because some contamination is beyond 100% correction .
there are times when it;s just too far gone to offer any assurances .
Cause it's a fact of life, some can be removed 100%, and some only "improved" ..and that's how you qualify the prospect
If you think you've found something that works better than every other product, lets here it!?
strong
oxidizers flooded into carpet and pad, followed by water claw and rinse have worked by far the best for us.
on severe ones, If they'll pay to replace the effected pad, the odds increase of 100% correction of carpet..cause while the carpet is disengaged , you can use a claw to pull rinse solution thru the material.
Stick the claw on, put an open QD on sol line and and let 'er flow thru the carpet into the claw
repeat oxy flood, dwell and "through the carpet" rinse as needed ...your "nose" on the carpet will tell you when if it's 100% gone or not
If
so severe they need the subfloors shellac sealed, forget about offering any kind of assurances of correcting the carpet 100%
Depending on replacement cost, replacement may be the better, more cost effective choice for the owner
Lets assume however, that you cannot use a truck mount machine to achieve these results. What are you going to reach for?
if no way to flood and flush/rinse extract,( BTW, a porty will work) you're pi55ing in the wind with spray 'n go topical treatments for anything but minor contamination
..l.T.A.
.l.T.A.
