I've had my GreenGlide holed teflon glide on my PC Quadjet for a year. It still seems to work fine, however is getting a little scratched up. Also has lost a lot of its curve on the bottom and is getting somewhat flat.
CleanEvolve said:... too many jets for a Legend according to the dealer.
c_adkins said:CleanEvolve said:... too many jets for a Legend according to the dealer.
Whaa? I think you need a new dealer.
CleanEvolve said:I think it's starting to flex, it started to make a slight hiss when I go from a forward to a back stroke. I'll order a new one.
Greenie...is there another quad jet wand out there that will work well with my Legend, but lighter than the Prochem quadjet? I looked in to the Titanium (which I really like) however, too many jets for a Legend according to the dealer.
Greenie said:I don't think their distributor is ignorant, just trying to communicate that their 20hp HX machine has limits, and htey want to stay within those limits.
Greenie said:you are near.
once they are truely flat, they drop in performance, at some point it will start to flex and give with each forward stroke, this will leak some air, it's simply thin and losing structural integrity, you could buy some time by securing each corner with a small bead of GOOP brand adhesive sealant.
C Pennington said:Is goop the best sealer for glides?
Greenie said:You are right on the money MeAt, 06 flow, I wouldn't go any larger on a Legend than maybe 08, casue the heat drop would worth the higher flow trade off...any more and he'll be unhappy with his 140º truckmount.
I've sold 12" Greenhorns with 06 flow.
